johndburton
I had inspection carried out by Tech 9 ( brilliant ) - Their findings and following report was very detailed and comprehensive.
One item was to replace the Al wheel nuts as they showed signs of corrosion and aging ( my car is 993 varioram - 1996 - 91,000 miles well cared for)
I got the wheel refurbished, I then replaced then nuts with new (from 911 design) tightened to 70nm torque - spec say 130nm.
I had to remove the wheels for a recent suspension rebuild. I was very careful to get full hex contact on the nuts and used a new 19mm full depth ( hex and not bi-hex) socket with a protection outer sleeve that fitted snugly inside the counter-bore of the wheel.
I sheared 2 nuts on 2 of the 4 wheels, I had to drill / end mill out what was remaining to the nuts to remove the wheels - A NIGHTMARE of a job.
The nuts sheared at the base of the hex where the section changes to boss part that contacts the wheel.
I'm thinking the replacement nuts material quality was NG ( the Al material spec used to make the replacement nuts was inadequate to meet the shear load ). The remaining nuts inspection showed how the aluminum had deformed / distorted during un-tightening.
Before I take this up with 911 design can you help - Has anyone had a similar experience??
As a general communication be very careful I can't describe what a Ba...st..d of a job it was, I damaged the studs (replacement required ) and damaged the wheels, may be beyond repair.
Thanks Best regards John
