The drop links are the connection between the end of the ARB arm and the suspension (as opposed to the mounts which hold the ARB to the chassis). As with everything suspension there is a compromise between harshness and rigidity and the standard drop link has small bits of rubber acting as bushes - getting rid of the rubber and the give it offers makes the ARB function more direct and more consistent and predictable, but at the expense of harshness.
Copies of the Weltmeister bars would probably be fine so long as they are quite faithful copies. The reason I bang the drum for the Weltmeister bars is that the fronts come with a lump of metal about 15cm x 4cm x 2.5cm to use as a mount (that isn't going to give at all), they are much stiffer than 968 M030, they use Rose joints and they have adjustment front and rear - smooth adjustment by means of a clamp round the bar, not the "understeer, oversteer or something in between" of the 968 rear ARB. The drop links don't like road salt unfortunately so I have kept mine well coated in anti-corrosion wax, but aside that hassle and the inevitable extra weight compared to the Porsche ARBs I can't see a downside and the benefit is clear.
