TTM
Well-known member
Fitting the 30 mm front bar on my S2 that already had M474 Konis with 968 CS springs has made the steering much heavier.
Given that 968 CS spring rates are the same as M030 spring rates I believe I would need either to switch back to the original 26.8 mm bar or to go with shocks with significantly stiffer valving to find back the original lightness of the steering.
Even with the bigger and wider front wheels a 968 M030 doesn't understeer that much.
