I disagree i'm afraid Vince (I assume that's your name). Pressurised gas systems are different unpressurised petrol systems and need to be approached with extra caution. Petrol leaks are easy to spot by a DIY'er, gas leaks are not. Also gas mixes instantaneously with air and is immediately flammable and therefore is much more dangerous - especially since the gas system is under pressure to keep it in the liquid state - a small leak of liquid gas leads to a relatively large amount of flammable gas due to its compression, and it would be a constant leak rather than an occasional drip, so you are talking about a hell of alot more gas resulting from a leak. Petrol has to evaporate before it can ignite therefore is more robust to ignition from a poor DIY job. One of my previous cars had a petrol leak I didn't know about for god knows how long as it was spotted at an MOT. The leak was a drip every 10 seconds or so right onto the exhaust manifold. Now i'm sure that it would have ignited at some point if left un-attended to, but the fact was it had been leaking for some time with no ignition. If that was gas leaking under the bonnet it almost certainly would have ignited if leaking, if not from the hot manifold from sparks from the electrical system.
There are alot of macho DIY'ers out there who think they can do a better job than professionals, and in most cases they can. But sometimes specialist knowledge and experience is required. I know specialist knowledge is now available and free on the internet, but how does a DIY mechanic know when and where specialist knowledge is required? I certainly wouldn't buy an LPG converted car that had been carried out by a DIY'er. For a start you have no come-back if something went wrong. At least if the conversion is traceable back to a an authorised person then you have more options open to you if something was to go wrong in the event it was found to be due to dodgy workmanship.
This isn't like a cylinder head gasket job - it is not just a case of satisfying yourself that the job has been done properly by turning the key and if nothing goes bang, you're good to go for another 100k miles. The risks with a gas conversion live with you constantly. A dodgy gas connection may be good for years of use and lull you into a false sense of security, but all the time it is an error waiting to rear it's head and bite you.
Maybe i'm a bit risk averse when it comes to things like this and maybe it is due to the conservatism I experience in industry when it comes to fuel systems, but I see no reason why the extra safety measures and requirements for specialist training observed in industry around things like this shouldn't be observed by individuals turning spanners on their own cars, central heating systems or anything else.
