ORIGINAL: peanut
ORIGINAL: 951Torqing
Yes definitely in denial. after upgrading from a 2.7 944 to an S2 and then to a Turbo (IMHO) the best of the 944's.
Look in the manual at the Power/Torque curves and compare the Standard S2 to a Standard 250BHP Turbo. Only below 2000rpm is the S2 more Torquey (Power about the same)
Above 2000revs the Turbo has considerably more Torque (and Power). Most Turbo users would not run below 2500 anyway.
The S2 only has the advantage up to 45mph ie the 1st 4 seconds of the journey, as soon as the Turbo is shifted into 2nd it leaves the S2 in its wake.
A suitably modified Turbo can have a greatly increased advantage over the S2, with no lag above 2500rpm
My Turbo continually gives me aching cheeks, not from the seating area though but in Smiles per Miles
Each to his own eh!
yes but for half that time you are in an S2 rear view mirror chum [
Its pointless to suggest a modified turbo would have a great advantage over a S2 isn't it ? of course it would doh
If you applied the same amount of money to modding the S2 you'd be back where you started with negligable difference in outright speed
I can see that you have never raced a S2 in your turbo or you'd see the evidence of the Porsche specs ie there is very little difference in outright speed over a set distance just a matter of a few seconds at best.
Anyway in an S2 you don't have to prat about dabbing the throttle with your heart in your mouth ,in a high speed bend, in the wet, wondering when the turbo is going to cut in and send you off the road in a big slide.[
