Tom (Augment) did detail the development of his board for the 944 here, I cant find the topic now but some of his early experience of running it is here https://www.porscheclubgb.com/forum/tm.aspx?m=725360
To me the advantage of Vems or Augment is that you are getting new hardware to replace the original ecu in a plug in box that means you could return to the original. The original ECUs are doing very well but a few have suffered from dry joints - corrosion etc. and this number is likely to increase, so overall you should see an improvement in the longer term. It may take a lot of hours on a rolling road to set up, iron out the bugs and additional tweaking may be required later. Another advantage over other standalone units is that with these 2 there has been a lot of work with our cars, others Emerald / Motec / Link etc. will require even more work.
On installation there are problems likely to arise with other components not being so 'fresh' - the ISV on my car was leaking a massive amount of air which with my Vitesse MAF which caused it to run very rich - so issues are not just found with replacement ECUs but they may be more sensitive to them.
So in answer to the original question - I have considered it but on my coupe, but still thinking a new factory GM ecu to match a new GM v8 - (If only I had time to get started, hoping to bring the coupe home this year which should help) and the cab I am keeping standard as tuning likely to adversely affect its value - If the ecu failed then it would be a hard choice!
Tony
Tony
