Badge Position Mystery
chrono
I was wondering whether someone could solve this mystery...
The badge on my Carrera (MY01) is set high on the boot whilst others I've noticed are set lower. Please see pics...
This is one I cropped from a members car photo here...
Hmm. Can anyone please tell me why and which one is correct?
I also have recently removed my black badge (see first picture) and replaced it with a silver one which looks fabulous. I'm just wondering now that by placing it in exactly the same position as the last badge I've actually placed it in the wrong place!!!
It should be as per your second post, your script is on too high. Doesn't matter really, put it on where you think it looks best.
ORIGINAL: chrono
Would the factory have put it on so high?
I'm confused... [&:]
I think the badges get put at Reading after the protective coating is removed. (?)
Mine (which is also a black badge) is in exactly the same position as your first pic (high). Very strange.
All the badges are put on at the factory NOT at Reading.
The badge was probably put on by a previous owner, with the car probably ordered with the deletion of model designation option.
Mine is higher on the lid, as per photo 1. Could it be that moving it to the lower position was part of the '02 facelift?
ORIGINAL: Richard Hamilton
That's exactly what I was thinking. Perhaps a few more 996 drivers would add to the list so we can see a pattern forming...
Not that it's that important or anything, but something that niggles... [&:]
ORIGINAL: chrono
make sure your wheel badge is facing the value too... [;)]
Saddo that I am, I've searced on the net for pictures of pre-and post-faclift 996s, as well as 911&PW with the 996 buyer's guide showing the rear of both models, and can confirm that Richard's hunch is true! The script was moved down on the facelift model.
Is this a world first? The spotting of another, as yet unknown difference, between pre and post-facelift cars?
I feel privileged to have been a small part of this find.
Group hug![:D]
Classic tread of Porsche Paranoia!
pre face lift 996 have the script above the second curve in the engine lid,
post face lift 996s have the script below in the lover curve, its done to tell the difference from behind.
its worth noting the replacement script is available in two sizes, but I hear only the new lower facelift size script is available, the C is a couple mm different in height.
Guys, thought I post the update as I had asked the Porsche engineer who came to the Ace BBQ the question about the Carrera badge position.
Well, he said that the badge has never moved and the right place, is below the curve as in the picture below. This is usually done at factory but can come debadged if requested and then the order is changed or a new owner takes over an order, in which case it would be placed at Reading when being prepared for delivery and he suspects that it may be in these cases that the badge could have been accidently placed over the curve...
Since this theory was first suggested, I've been testing it on the roads, and not once has it failed.
It hasn't failed on any of the 'net or magazine images I've seen either, and I don't believe they were all 'mistakes'
Prove the theory wrong Kish![8D]
The PET shows two different badges and part numbers, one for early cars, and one for facelift. It also shows their position as 'upper' and 'lower'.
