peanut
fair point but we are not talking about arc welding here.[8|]ORIGINAL: GMcMillan
Hi,probably not a great idea to disconnect & reconnect a battery terminal to check for arcing as Bosch ecu's don't always like this,
Just touching the earth strap connector to the battery terminal will tell you if there is the tiniest battery drain. Difficult to describe in text easier to demonstate.
You could always disconnect the ecu during the testing. The point is its easy straightforward costs nothing needs no test equipment and works every time[
