Battery trickle charger / battery conditioner
- Thread starter mohamos
Chrishazle
I've only ever seen good reports about CTEK (I believe the Porsche conditioner is just a re-badged CTEK at Porsche price!!), and I've seen this question many times between the 4 car forums I frequent.
I'm certain that using a conditioner is good for 2 reasons - it means the battery is fully charged whenever you want to use the car, and I'm certain it enhances and prolongs battery life. My 968 coupe had a 10 year old battery in it when I sold the car, it was still going strong, whereas the car had 2 batteries in the first 7 years of it's life (only 2 1/2 in my ownership, and at that time I did not have a conditioner).
https://www.porscheclubgb...OWN+CTEK+Porsche+Forum
matt_muller
Motorhead said:Sid,
I've used a CTEK conditioner continuously for the past 9-years and have been very pleased with it.
Others I'm sure will be able to provide alternative recommendations.
Jeff
hi I'm also looking for a charger:
997 Gen 1 C2
Do you connect the CTEK directly into the cigar point? or to battery terminals.
My options which I'm considering are: Porsche version or CTEK MSX 5.0 - I'd rather use the cigar connector.. for ease of use.
if anyone has any experiences with these Great!
(sorry for piggy backing on this forum question but thought it may help)
matt_muller
Lancerlot said:Take a look at the link tscaptain provided in post #4. It's all in there. []
Regards,
Clive
That link doesn't work for me?
matt_muller
Motorhead said:Matt,
Just to say that although I started with using the cig connector I favour the reliability of direct connection to the battery terminals using either the croc clips or the flying lead provided by CTEK.
Jeff
On the video's CTEK MSX 5.0 says to connect earth terminal ? rather than negative.
Sorry, hadn't realised you were not a Club member. You have to be a registered PCGB member to access some forum areas.matt_muller said:Lancerlot said:Take a look at the link tscaptain provided in post #4. It's all in there. []
Regards,
Clive
Regards,
Clive
matt_muller
Lancerlot said:Sorry, hadn't realised you were not a Club member. You have to be a registered PCGB member to access some forum areas.matt_muller said:Lancerlot said:Take a look at the link tscaptain provided in post #4. It's all in there. []
Regards,
Clive
Regards,
Clive
ok thanks .. I'm going to join just not got rund to it
Chrishazle
matt_muller said:Motorhead said:Matt,
Jeff
I'm sure either will be fine for your 997 but I've used the negative battery terminal with no problems. There's a gap between the windscreen and bonnet through which you can feed the cable.
I think that connecting to an earth terminal was required for the 991/981 series cars to keep the battery conditioning in circuit.
Jeff
