Bedding in brake pads
- Thread starter milnsey
Greenman986S
In general over the many pad changes to many cars I've had, gently does it for a few miles, esp if he only changed the pads and kept the old discs.
Surprised he did not change the discs at the same time?
The new flat pads need to be eased into the surface grooves of the old disc. to maximize the surface area between them when braking.
Some very high performance pads need a very different approach but the packaging usually gives advice from the manufacturer.
I changed the front pads and discs on my 987.2 4 years back with standard parts and the brakes felt perfect straight away.
All a bit like running in a new car, same thing.
I would not have used oem pads though, new EU rules and the pads are like chocolate now days with much less bite. RSC1 or MX are the goto pads on PCCB.
A pad like the RSC1 you can buy now pre bedded and cured even for a little extra money.
But yes def worth a few high speed stops like I have instructed.
Greenman986S
