Best Cayman Pictures
- Thread starter ralphmusic
After one of those all afternoon cleaning sessions.jasonbowman said:[attachImg]https://www.porscheclubgb.com/forum/download.axd?file=0;1056663&where=message&f=image.jpeg[/attachImg]
Cheers - Paul
Teesdale in February 2015. I see I've ended up with two pics (like some others before me). Maybe I need to read the 'help with photos stuff'...Maxym said:[attachImg]https://www.porscheclubgb.com/forum/download.axd?file=0;1057224&where=message&f=Teesdale Cayman S.jpg[/attachImg]![]()
failed link to https://www.flickr.com/ph...-2iQFMPq-pmUDY4-m7LcRV
and another copy of the same image (this is displayed) loaded up onto the Porsche site with the PCGB watermark.
I realise you will have tried the several ways of loading images but let me just run through the basics for others. In the top bar of the "Reply" frame i.e the one I am typing in as I write this, you will see one row starting with B and the last is Font Size drop down. On the second row, you will see a happy emoji and the last a tiny picture frame with a + sign.
Click on this tiny picture frame with a + sign and it will return a small new window "Image URL" Enter your flickr url link* into the box i.e. as I am about to do click on Insert and that's it save for any extra text you want to add.
* HOWEVER none of the Share urls offered by Flickr worked directly so I tried various versions until I found one that worked. I used the url "https://live.staticflickr...9c5c92b4d_5k.jpg" which is a truncated version of the BBCode offered by Flickr "Share" menu as below.
You can check what you've done by pressing Preview.
I have no idea why the Flickr Share option urls don't seem to work but hopefully someone more used to Flickr can come along and provide better advice than I can.
NB the Flickr urls displayed above will not work if you click on them - another oddity.
I use postimage.org which is a walk in the park.
If you just want to display a single image the easiest way to do it is to use the Open Full Version option (next to Quick Reply) which opens a new window in which you can Upload file(s) to the server. Note that you can only upload 1 file with a max size of 1500kB.
Jeff
