I am such a prat!!!!! [
I had a friend look over the car at the weekend (not a mechanic, but a lot more knowledgeable than I) and he seems to think that there is nothing wrong with the car. [
] at least not with the head gasket
Let me explain;
Firstly, what looked like oil (to me)in the expansion tank was just the green dye that was added to the coolant when the new A/C condenser was fitted with the CFC free gas, this through the off colour expansion tank looks black. Coolant must have been on minimum because I have not noticed before [>:] (Did you not take the top off to check you prat!!! I hear you all shout [
]), well I did, but obviously with it being hot all the coolant started to rush out, so top went straight back on [>:]
Oil level when he rechecked was a little lower, but nowhere near when I checked (when panic attack set in [
]) guess I didn't leave it long enough to drain DOH!!!
His diagnosis was that I am paranoid and need help [
Anyway chaps, thanks for all of your help and advice and I promise next time I post a thread it will not be from an imaginary problem [
Actually, this does lead onto a question, does anyone know of a specialist (in the london area preferably) that could check over the car to give me peace of mind and to set the car up as it should be???
