Boooooooooooooooost!
- Thread starter scam75
PSH
PSH
something that I read recently and did surprise me is that when launched the 951 had the fastest 0-30 mph time in the world, I'm not sure how accurate this is though, I've always thought as you Stuart that it doesn't like fast launches. Having said that I have surprised myself over the years (including before modified) just how quick the 951 can be with an aggressive launch, perhaps I'll look more into this claim at some point in the future..scam75 said:I've always felt the 944t comes alive after 60mph. It's a harder car to get going from standstill than any RS ford. I do think the 944t is a beast from mid range onwards though which suits me now as my grand prix traffic light starts are a thing of the past!
PSH
Haha...I didn't say that I was going to try it out...as my wife keeps telling me, 'I drive like an old man these days' ..scam75 said:Sounds like fun Pete, take care of that expensive clutch when trying!!
blade7
Well-known member
PSH said:I would disagree Paul....to put it in JC's words the RS500 tried to be a 944T with similar performance (in fact the standard 220 951 was faster) but was much more agricultural in comparison. It probably felt quicker due to the higher lag/greater punch when hitting boost. In fact, it was nearly 1/2 slower than the 220, RS500 being given a 0-60 time of 6.1 to 6.3 whereas the 220 was 5.9 to 6.1 depending on which road test you go by. The 951 was more than a sec quicker to the 1/4 mile and faster top speed although they are close. I wouldn't say the cossie was more planted either, in fact, it had a reputation for lift at high speed. The 951, on the other hand, is still the most planted car that I've driven, it's just as planted at max speed as it is plodding around town....
Having owned a Cos for 13 years and 944T for 10 Pete, I'm going to have to disagree with you. TBH I wondered what all the fuss was about with the Cos when I bought it, 18-20lbs boost turned it into a totally different car. The 16V head and relatively big turbo mounted close to the head hit harder on boost IMO. Moving on to down force, I had my 3dr flat out many times on country roads that I wouldn't dream of matching in a 944. Having said all that I still think the 944t is a better built car, when I sold my Cos with around 60k miles, the engine and gearbox were overdue for a rebuild.
PSH
It did try and kill you though when it was even moist on the roads, great car but could not put the power down in certain conditions, first car I did over 150 in, in Germany of course oshifer ??
PSH
cheers
Pete
TTM
Well-known member
scam75 said:Could never get it to run right with 55lbs injectors and the chips I've got. Goes fine with standard. Do have an uprated fuel pump. Must have hit about 27psi when it pinked which is understandable.
Have you tried adjust the boost with the MBC to the level the chips are programmed for?
scam75
Well-known member
So I got the wastegate off and the diaphragm is holed. The Lindsey wastegate re-uses parts from the standard wastegate, there is a bowl type plate which the diaphragm sits on, which is a part from a standard WG. This had corroded somewhat which in turn has damaged the diaphragm. Couldn't source a diaphragm from anywhere except Lindsay themselves. Just under £100 delivered. I will clean up the offending plate and rebuild it when the diaphragm arrives. I've shoved on a standard-ish single port WG for the time being which is holding 12 psi. I haven't bothered plumbing in the boost controller so it's just feeding straight from the banjo bolt. Car running fine but will be nice once the rebuilt DPW is back on. Does make quite a difference.
Stuart
TTM
Well-known member
scam75
Well-known member
Stuart
scam75
Well-known member
Stuart
PSH
I think I understand what you mean, think mine was the same although can't recall for sure. BTW if you want a quicker spool fit a spacer under the spring, it makes a big difference...IIRC I machined up a 4.5mm brass spacer, worked a treat. A much better design than the Linsey shims as they reduce the valve opening..
Pete
