Indi9xx
ORIGINAL: pauly
ORIGINAL: Indi9xx
With valves modification to the profile over the years has been a hot subject. In particular there are modifications which can be used to allow you to use a cam with more overlap while controlling flow direction and reducing low rpm backflow during the cycle. As for valve mods to improve swirl, its one of those things that it would be interesting to experiment with.
Are these the valves that were around 20+ years ago with a groove machined into the face of the inlet valve to limit back flow during overlap and a step on the back of the exhaust valve that supposedly reduced exhaust backflow ?.
Your probably thinking of the Rimflow valves which were often in vogue in the late 80's which are a good idea on paper, never had a chance to test any Rimflow's. There are very similar things that can be done but I need to keep some things close to my chest.
