Boot struts
- Thread starter Big Les
Diver944
ORIGINAL: j16jrf
so when the button is pushed should the glass actually life on its own?
Yes - new boot struts will return your hatch to catapult like performance as soon as you press the button [
Does the motor in teh hatch 'whirr' when you press the button? If it does then you probably have a broken cable back there - peel down the carpet and watch what happens as an assistant presses the button. The cable is under a tenner from Porsch-apart (I think mine was ÂŁ6)
georgethackray
georgethackray
Exactly right - according to my PET, the part number for the cabriolet is 941 512 348 10 and it's the same each side, whereas for the S2 Coupe, it's 944 512 348 00 for the RHS and surprisingly a different code for the left - 944 512 349 00.
So it's possible that the companies who sell cheaper ones wouldn't have had any suitable for my car, in which case I would have had to go to Porsche anyway.
I'll keep telling myself that, then I don't feel as bad for paying more!
sawood12
Enjoy the tailgate opening on its own while you can as it doesn't last forever. I changed my struts with a new pair from Porsche apart last year and now my tailgate only opens on its own sometimes. If it doesn't then giving the drivers door a firm but gentle slam will create enough pressure in the cabin to just push the tailgate up enough for it to open itself!!
I suppose if you fitted a tailgate wiper delete kit the tailgate would open with such force it'd be classified as a lethal weapon without the weight of the wiper.
georgethackray
With it being a Cabriolet, I don't even have the luxury of ditching the wiper!
Next time, I'll go for some Heath Robinson approach and use rubber bands or something [
Diver944
ORIGINAL: georgethackray
I thought it would be good for a few years at least.
Don't forget you have a two year guarantee with all parts from an OPC [
I don't know what happened to Scotts (maybe duds [&:]) but mine are still going strong after about 4 years.
Fred Hindle
Cheers,
PRJ
ORIGINAL: wizard
The only problem I have had with since fitting them, and not sure if it is down to the struts, but my interior light would not switch off. This was traced down to the connectors on the offside strut - I have left it unconnected for the time being since whatever I do does not fix it.
Same problem with mine when I replaced the struts. I've removed the connector too as I can't sort it either - My electrical knowledge is pants tho [
Hilux
I`m surprised that the tailgates are supposed to open all the way on their own. I`d rather have mine the way it is in case it came undone while moving.
georgethackray
ORIGINAL: PRJ
ORIGINAL: wizard
Same problem with mine when I replaced the struts. I've removed the connector too as I can't sort it either - My electrical knowledge is pants tho []
Did you replace the struts with OE Porsche ones? - an earlier post confirms that the struts form part of the circuit, so I would guess that the strut in question is either faulty or if its not OE, then maybe it doesn't have a 'switch' in it.
georgethackray
Cheers,
