bose
- Thread starter matt643
The BOSE amps are fitted in the front boot (I think). You'll also need these.
An easier option would be a decent aftermarket system.
Taz
Do you happen to know if all the wiring for the extra amp and speakers is already in the loom for the older style sound upgrade? I have seen a couple of the sound upgrade amps for sale on ebay at very reasonable prices and thought this may be a cheaper route to a decent sound system.
Matt
penfold944
The BOSE is ok i think - but I found I had to turn the bass and treble up to about +8, and that you really need to have the volume up quite high to experience that sub woofer
David White
I'll try the bass at +9 though...........
I have already sent the car back to be checked and they said it was ok. I have also checked that 'auto' setting is off (so it doesn't auto alter depending on car speed)
Despite this, the sub woofer volume seems to cut out then come back on - no pattern, no common factors
I think it may just be the way it is but could just be me. I haven't tried Bass & Treble turned up, though - will try this
Rich
Black80XSA
penfold944
One of the biggest advantages of 'subs' is that they allow the other 'drivers' to work within their defined frequency range and not have to also produce low bass frequencies. Therefore, one of the real advantages of getting a sub is, ironically, better midrange. A good sub, usually isn't heard very much. Bad 'speakers (subs) produce the 'boom boom' heavy bass inaccuractely associated with good 'speakers, but real bass isn't like that at all.
Also most 'subs' should never actually be called subs, especially in cars, they don't usually reach any kind of 'sub' level. The reason why you have to turn up the wick so high to hear any bass is because they are small and cannot physically produce audible low bass frequencies.
So the solution is get 2 x 10 inch drivers behind each seat, get a power amp to handle each channel....and while you're at it, get some spinners for your alloys, and those oh-so-this-season neon lights to go in the washer jets.[
I have an april 04 boxster s cele bration model with a bose system and it has been back to garage countless times . The volume is erratic and sometimes when you switch on ignition it comes on at full volume . They have repaced the unit and yje amp . Not as bas as it used to be --it would refuse to come on or increase vol without warning . They also say that Porsche do not know of any problem . I do not believe them
Bob davidson
Does anybod have any pics of there audio installs ?, would really like to see how others have fitted there speakers.
ORIGINAL: mistasmiff
I've heard of folks putting 10" subs behind the seats but I really can't see how anybody could fit anything behind the drivers seat. I'm only 5 ft 10 and the sit is all the way back and it's still not quite enough.
When people say behind the seats they mean the storage space (I hope); the Bose sub comes in the horizontal space in the centre space (the shutters in the pict below). Also, the pict below shows the rear speakers option available in States but not to us:
I suspect you get a different amp as well...? (I haven't got it and the details are not at hand).
The wind deflector can usually be left in position - I can't see why the average driver would ever need to remove it (apart from for cleaning the rear window) I only ever remove it to fit a camera mount to the roll over bar when on track.
