ORIGINAL: j4mou
ORIGINAL: morris944s2john
I'd say by now the car would possibly need new cams, as well as a new clutch due soon and almost certainly would need new wishbone ball joints. That lot together would equal 3K+ if done at a specialist.
what would it cost for that lot to be done? are you basing the work that may need doing on the mileage?
cheers
James
I've had cams done on both my S2s. My indie reckoned when I last asked him he could do cams for unerd £1k all up, which is
cheap but it depends on the Euro exchange rate as he's cheap because he found out who makes them for Porsche and can get them at trade price, which I understand is difficult with this particular part. Costs I'd suggest are £1,000 to £1,500 for cams then.
A clutch change on an S2 is anywhere from £600 to £1,000 would be my guess. Costs can rise if other things need to be replaced, but should be in the lower part of that range with luck.
Ball joints are as per any '87- 944. Recon units are sub £200 each exchange (new are about £200 more each), fitting and alignment afterward might make it a £650 job all up - knock off something like £200-£225 if only one side is being done.
All-up that lot is in the £2,250 - £3,000 range. To be fair that's the bulk of the likely non service work (perhaps a caliper refurb for plate-lift could be added).
I initially suggested the cams probably need doing based on my experience. They fail through age and/or mileage. Sometimes the case-hardening is starting to fail which I understand can happen on lowish mileage cars. I know of a cab which was bought just before my Turbo in 2001 that had cams a few years later. It had 67k on the clock in 2001 and doesn't get used all that much; I think it had 80k last time I spoke to the owner. It's also possible for teeth to have worn badly and in the worst case to shear off. We had someone on here a few years ago who ended up spending north of £3k recovering from sheared teeth and he then had to sell the car on to cover his costs, the sad reality being he'd actually have been better off breaking the car than fixing it.
I've said before that I would only buy an S2 paying at least £1.5k less than its true value to cover me for cams unless someone I trust has looked at them recently and pronounced them OK, or that it has had them replaced relatively recently. i did that with my cab and it needed them, so I didn't get it as cheap as I might have done, but I didn't have an unexpected bill on getting it looked at post purchase. I personally can't see that replacing the chain alone is good practice as it's just a bike chain and you never replace a (motor)bike chain without also replacing the sprockets, butplenty of people will tell you it's been OK for them. Time will tell is my view if I'm honest and I'd like to see the sprockets of a 175k engine 50k miles after just the chain was replaced to see if, as I suspect they would, they have accelerated wear.
Clutches clearly can last massively different mileages depending how the car is used and driven. The S2 clutch has a rubber centre instead of springs (not unlike a cushion drive on a motorbike) and being rubber that clearly will degrade over time. I had one break up and you'll know if you look at one where it has falied because you will not be able to disengage the clutch, or it will have the mother and father of backlash on/off power. I got approximately 0 seconds warning it was going to fail; one gearchange fine, next not possible. I then spent a few miles messing with it and got it to break up completely so I could get gears smoothly, but the backlash was there by that point of course. That suggests to me that an old clutch in an S2 needs to be considered a possibly and sudden failure point regardless of whether or not it slips.
I've only had to replace one ball joint in 5 944s, and the car drove dangerously it was so worn, but lost of people need to replace then so it's a valid item to consider.
In terms of chap 944s the one with the failed ball joint I bought like that at auction. I paid £3,550 for it - a 1989 250 turbo in satin black - in 2000 when they were going for circa £10k at least. I fixed the ball joint and outed it for a £50 profit as I could see even owing me 40% of the market value of a reasonable one it was going to be an uneconomic money-pit (it had paint defects, didn't run like it should, needed brake attention etc. etc.). Parts and labour haven't got cheaper since 2000 so by that measure there are a lot of 944s around today that are literally not worth paying anything for, unless you want to break them for spares.
