AmericanSuccess
malarcy said:If you don't already have the Y Cable that gives the 30 pin "old style ipod" connector - you can also use something like this
TUNAI Firefly LDAC Bluetooth Adapter: Hifi Wireless Audio Bluetooth 5.0 Receiver with Audiophile USB DAC 3.5mm AUX for Car/Home Stereo Hi Res Music Streaming; Auto On, No Charging Needed https://www.amazon.co.uk/dp/B01HXXJPWK/ref=cm_sw_r_cp_api_glt_fabc_S9ES6TQQP0HY6B5FM45G
(assuming you have usb and aux sockets ) one end in usb, other in aux and pcm set to aux input ( if you have the socket and the option doesn't appear in the pcm - there's a menu option to enable aux as an input option)
That's an interesting little device! As with Rocky do you connect your phone to the cars Bluetooth as well or do your calls come through the Aux port with this device? Thabks
