Boxstercol said:I agree with some of the above.
Had my 987 for coming up 3 years, it replaced a 986 which got written off in a non fault accident after 3 months of ownership. For me it's a weekend type car with occasional use during the week. It replaced a Eunos Roadster (Japanese imported MX5) which was a fun car but not on the level of the Boxster.
Running costs are huge in relation to the MX5 - tyres / brakes / servicing. Pretty much everything that has the word Porsche associated with it results in further cost, but that's just the nature of the beast.
I don't necessarily agree with buy the lowest mileage one you can. In my experience when I was looking for a 986 & then a replacement to my written off 986, most low mileage cars I viewed had skipped services / maintenance as owners basically didn't seem to want to spend the money on them as they thought that jobs could wait if they're only doing 2k per annum. Also, these cars do not like to be stood up without use - there is a train if though that suggests 'garage queen' Boxsters are more prone to IMS issues & RMS leaks (as seals dry out).
My advice would always be buy on condition. Whether the car has done 40k or 80k, look for condition every time plus a thorough service history. 987's have a 2 year / 20k service interval. A caring owner who looks after his car will get the oil & filter changed annually regardless.
Some of the things to look out for:
- Brake disc corrosion on inner faces, could result in changing discs & pads - caused by lack of use / not drying brakes off after washing etc
- Air con condensers
- Brake line corrosion
- Tyres - dependent upon size could cost up to £1k fir premium brands
- Corroded exhaust brackets
- RMS leaks - however this could be the IMS seal leaking, only way to find out is by dropping the box
- Broken springs quite common on outer roads
- Squeak / creak over rough surfaces could be suspension needing a refresh, normally the longitudinal arms or coffin arms
- water ingress into the cabin caused by blocked drains - can end up frying the alarm ECU under passenger seat
- water pumps tend to fail at circa 60k miles
Hope this helps.
those are the very small cost items, you need to be looking at the bigger items
shocks
top mounts
all bushes
brakes
all copper lines
wheel bearings
hubs
all rads and pipe work
exhausts
clutch
flywheel
body work
gearbox if high miles
caliper rebuilds
Rust on lower A pillars
starter motors
as I say you want to see some of this work done on a 16 year old car for sure other wise you are in for a shock, I don't run shocks past 60k miles, many will and so it goes on.
it's a mine field hence why a rebuild on a classic is £60k+ even £80k for a proper restore.
a 10 year old 911 will swallow £15k for a refresh, A Boxster is the same car done and said all.
