Braided fuel lines
Dandrews
Hi everyone, replacing my fuel lines (40 years old) and went for braided hoses , for longevity and easy fit . Having problems with sourcing brackets/clips to attach to underneath car. Anyone bought these hoses(uk) , and have experience of fitting to underside . Thanks D.A.
The clips for the original hard lines were cheap enough and available from Porsche a couple of years ago when I purchased them. Check with Porsche, that is if your braided lines will fit into the OEM clips. If not you'll need to come up with a solution.
Stuart
Thanks for reply Stuart , I have a set of new Porsche clips , unfortunately they are much smaller than the braided hoses 1/2” (13mm) o/d . I have a set that I bought from the supplier of the hoses . Was hoping someone on here had fitted new hoses . Might have to refer back to original solid pipes !!!
Thought about that one Clive . Problem is 2 fuel lines ( supply and return ) with only one self tapping screw on underside of car . Would require a double cable tie bracket which doesn’t seem to exist !
Not sure I quite understand the problem. Along with the solutions below there are also adhesive backed anchors available.
Regards,
Clive
Here's another solution for running the lines together in parallel.
Regards,
Clive
You've gone rather quiet Mr. Andrews but here's another possibility if the others don't suit.
Regards,
Clive
