Brake disk wear
- Thread starter Guest
I am not supprised the pads need changing (48,000 miles) but I was supprised that the disks need it to. The other suprise was the rear pads needed doing at this service. I would of thought that the fronts would wear before the rears.
Graeme
Talking to a good friend of mine in the motor trade, he say's disks and pads should be replaced together, and it is a false aconomy to just replace the pads.(sometimes with vented and cross drilled disks cracks and corrosion can cause them to break up!!)
The materials of the pads are a lot more abrasive in modern cars so wear the disk as well as the pads.
But as JCB say's fit them yourself and save a load of cash, I did.
I may well be in a similar position and when I spoke to some aftermarket specialists (performance parts and car specialists not independents) they claimed that to do porsche brake and disc job you needed special tools to complete this... from what I am hearing here this ain't the case.
I've never attempted anything like this before is there anywhere i could get the idiots guide to changing the discs and pads? Also OPC are quoting £1200 + vat vs JZ Machtech £685 + vat. How much did you pay for the parts only from porsche shop? and do you have an URL?
Would welcome any advice as £800 is a lot of money in anyone's language.
G
Whaaaaat????
In my experience in a "normal" car you can expect to get through a set of pads every 12,000 miles average..... You can also expect to see the same discs on at 100,000miles.
Relate that to a porker and if you drive a bit aggressive you will see out a set of discs around 50k with pads every 6-12k.....
JCB..
Non-member
Well I don't drive like a looney on normal roads but the first two sets of pads and 48k miles included:That must be your verrrrry agressive driving style
6 days on the IOM plus a Jerby trackday, Silverstone, Donnington, Castle Combe and Mondello Park track days.
JCB..
Paul Fraser
1. drive/brake harder to keep the discs shiny
2. use the car regularly
3. make sure you take the car out after washing and heat the brakes up so they dry off.
IMHO, 40,000 miles for a set of Boxster discs is ok. They are quite cheap if you replace them yourself.
Black80XSA
At least you had the sense to go outside the OPC network - they would have charged you £1300 just for the brakes
ORIGINAL: kentim
Don't know why this forum shows me as a 'non member' - I've been a PCGB member for years, I'm logged in, and I'm subscribed to this forum!
The secret is in the email you were sent when you joined the forum [
