Paul Fraser
Failed MOT with front brake imbalance (35-40%) after fitting new discs and pads to cure offside vibration.
Tester suggested it might be the hoses so I replaced the underperforming nearside last night with a Goodridge and the rhs still locks up before the lhs and there is slight pull to the right before that.
What is next: I'm pretty sure I checked the lhs caliper funtion and WD40d the piston while doing the disc but I'll check again. Do I need a new caliper, or will a rebuild kit do? Could it be anything else?
