Brake swop.??
- Thread starter Big Dave
I'm assuming you have standard S2 callipers, as those first fitted on the 220 Turbo, not "medium blacks". This being the case they will have mounting ears on the back of the calliper so you bolt then from behind in the same way the original floating calliper is mounted.
An 88 Lux should have ali lower wishbones, and the later hub, so with 220 turbo discs, you might be in with a chance. I'm only saying "might" as Porsche have a nasty habit of changing components subtly and it isn't always easy to get a match or relationship even armed with PET. Generally all you can establish is how many alternative versions are available for the component you are looking at.
It does look like this might be a case of suck it and see.
Peter Empson
However personally I'd strongly recommend he just has the standard calipers checked over to ensure they're working properly and get some proper pads fitted (I use Porterfields) and ensure the hoses and fluid are both good.
Even at very hard braking tracks I found it impossible to get fade, and the feel was great with a really solid pedal - better than with the larger calipers, plus you have lower mass and don't need to fit bigger wheels. With good pads I was comfortably out braking much lighter cars like Elises with no problems for many laps at a time.
I only upgraded as I was doing the suspension and knew that I'd be fitting a bigger engine in the near future.
Best regards,
Peter.
sawood12
Didn't the S2/turbo have a completely different lower wishbone set up to the Lux's using forged Alluminium wishbones instead of steel ones??
Peter Empson
I believe the later Lux's had the same wishbones, and it certianly wasn't something I remember having to buy for mine.
Best regards,
Peter.
Based on the 1988 product line
Wishbones, 4 types, 3 of which are post 87 (ali?), 1 of the 3 is M030/758 (Note: M758 is medium blacks without M030).
So you have one of two wishbones, neither of these are differentiated as Turbo so a 50/50 chance at the worst
Hubs 5 types, 3 post 87, 1 of which M030/758.
Again you have a 50/50 chance at worst.
Now the problem steering knuckle. The steering knuckle is the bit that the hub, strut, calliper and steering arm bolt to. If this is wrong you could end up with the wrong mounting for the calliper, it could be too far away, or off line. Also, you could end up with the steering balljoint being too close to the back of the disk.
There are 7 types of steering knuckle, 5 post 87, only one listed as 944/944S the others Turbo or M030/758.
Both the Lux and S have a floating calliper so it would look like they have a specific steering knuckle - the others are different so I guess Turbo/S2 callipers aren't going to fit.
The more I think about this the more likely they are not to fit. When we fitted M758 brakes (medium blacks) on Baby Wuf (Rick's 944S) we had the wrong radial mounts. This suggestes that the radial mounts for a Turbo and a Lux or S are obviously different - IIRC the distance between the calliper mounting bolts were different.
I summary - I don't think they will fit.
sawood12
sawood12
Didn't Rick Cannell use medium blacks on his mini-Wuf Lux??
frogisland
Was trying to aviod adaptors etc - might as well buy a used S2/968 hub/spindle/strut setup if necessary.
Thanks though for all the info, plenty to pnder over.
ORIGINAL: sawood12
.......Didn't Rick Cannell use medium blacks on his mini-Wuf Lux??
.......When we fitted M758 brakes (medium blacks) on Baby Wuf (Rick's 944S) we had the wrong radial mounts. This suggests that the radial mounts for a Turbo and a Lux or S are obviously different - IIRC the distance between the calliper mounting bolts were different.
Don't worry I'm getting used to people ignoring me.
