smallspeed
Im looking at the brakes on my car; one of the rear calipers is sticking a bit and could do with a re furb, however Im considering upgrading the rear calipers then fixing what I have and selling on to re coup some of the expense..
I think (put me right if Im way off track) that the C4 and RS had the same front calipers as the C2, but the rears are larger 4 pot calipers (RS got the same rear calipers as C4)..
Also the master cylinders are different; I think the C4 master cylinder is slightly larger (prob to cope with larger piston vol from bigger rear calipers). The RS master cylinder is larger again as I understand it but not sure why, poss same as the turbo?..
I also believe one of the other main performance advantage between C4, Turbo and RS vs C2 is hydraulically boosted brakes vs vacuum..
So if I were to upgrade my rear calipers as stage 1 of a future upgrade program (ie eventually going to big blacks/reds on front with x-drilled RS disks, C4 rear calipers with std disks) what should I do?..
Im thinking I should upgrade to C4 rear calipers and the C4 or Turbo/RS master cylinder. My concern with this is whether the C4 master cylinder is big enough to cope with big reds/blacks when I get around to upgrading the fronts? hopefully someone with a C4 and big reds can comment [
My second thought is to replace the vacuum assistance with the hydraulic power assistance but Im not sure whether this is feasable? I dont want to get into replacing lots of big expensive parts as a knock on effect of this (ie ABS pump, ABS ECU, etc..) Is there really that much benefit in doing this change and would it be worth the effort/cost at this stage in preperation for the front end upgrade..
Hope someone can comment on my assumptions and provide some insight into my planned upgrades!..
Ben
Ben
