Bushes
Not writing from experience but if I understand correctly the ball can wear through into the wishbone itself so the wishbone needs machining and bushing before replacing the balljoint.
You can get OEM ball joint replacement kits, and I did mean Hartech and not Autofarm regarding the machining of the wishbone socket.
What happens is that the plastic bushes that line the socket (acting like cartilage in your knee I suppose) and the ball can wear through quite quickly so you have metal to metal contact and in a battle between Steel and Aluminium Alloy Steel will always win so you get wearing of the alloy socket. IN the aftermarket kits (like the Rennbay ones for example) you can replace the plastic bush for Phosphor Bronze which not only provides more positive response but also resists wearing as Phospor Bronze. Also my Rennbay kit has a grease nipple so you can replace the grease in the joint at services. However even with metal bushes if the shape of the socket and the ball is not the same you will get high spots and wearing so Hartech have developed a machining method to machine the socket back to a conforming shape. Obviously there will be limits such that in cases where the socket is particularly heavily worn the arm may not be salvageable.
I guess you can always simply replace the ball joint without restoring the socket geometry and you may get away with it during the time you own the car.
as a wee note guys, i had a shot ball joint and rebuilt it myself with kit from porscheshop. Its was ok at first, but 6 months down the line, its was knocking again and proceeded to fail its mot. So bit the bullit and bought rebuild wishbone from hartech. The ball joint kit was a quick fix but didnt last, probably for the reason everybody mentions above. To check your balljoint you are best to keep the cars weight on the wheel and simply put a lever between wishbone and hub carrier and see if there is play, although you can usually feel it through the floor when driving along with the knocking.
