I went to see a 52reg C4s last night. With 43k, no service book (got stolen) and i know that a service has not been carried out on it for about 2yrs because the owner said hes only done 4k in it for that period of ownership.
He did say he had a OPC 111 check on it when he bought it, which showed nothing major wrong apart from the slight leak at the clutch casing.
When i checked the oil level, there was none in it and mayonnaise was around the filler cap. The owner said he dosent use the car often and dosent know much about cars. The oil pressure was on about 3bar on idle, there were no major oil leaks and no smoke blowing out. Should i be worried?
Do C4s use up a lot of oil? Can the mayonnaise be due to lack of use? Is the oil pressure to high?
The rest of the car seemed ok, although he did say he has filled up the coolant, but again i couldnt see any leaks in the usual places.
Any views?
Any views?
