Well got them off finally and they are in need of some TLC to say the least. Boy those bolts were tight (but you would hope so I suppose!!)
Anyway. I finally managed to get the pads off, but on of the anti rattle weights was seized in the piston o each calliper. Looks like when I put them together I will have to just take a weight off the new shims.
Anyway, spend tonight pondering on the next step, no question the plates will have to be replaced, but how to get the old ones off?
Well got stuck in to first calliper and managed to get one plate completely off, but others not having any of it. I used some locally applied heat on each grub screw. Haven't even tried to get the bleed nipples loose yet, that's tomorrow's fun.
I am going to phone around a few local engineering shops on Monday see if they can help with the plate removal, well its got to be cheaper than buying new callipers!!
As for the disks, it looked to me like the inside face of each disk was much more unevenly worn that the outside, and I think some of the old pads have fused to the disk. I wonder if the outside gets slightly better cooling.
The disked measure out at 31.5mm and 31.6 mm so they are in good shape from a wear point. There was never any sign of juddering last year so I hope that the new pads etc will clean them up. I suppose it would be prudent to take them off and get them skimmed but that's much easier said than done. Oh why wont people use copper grease on the disk locating screws"¦Arrrrrrrrr
BTW MC2 worked a treat at cleaning the callipers.
