sawood12
ORIGINAL: VanhireBoys
Chaps
On a different note the service interval for the belt on a Focus TDDi is 100k miles. I got both the belt and tensioner changed at 80k and the dealer said I was being Paranoid ! I would change the belt and tensioner on a 944 every 30k or 3 years just to be safe....!
Yes i've got a Focus 1.8 zetec and that is also 100k interval. I'm sure technology has moved on over the years and when the 944 was a new kid on the block. I'm sure the belt is good for 100k as Ford recommend but I too am thinking about replacing somewhere between 80 and 90k miles.
I can't believe how much of a big deal people make out of timing belts. It's just a service item like any other. Just change it and forget about it. On the 944 change the balance shaft belt as well as they tend to take out the timing belt if they go. My idy did my timing belt for under £400 which isn't a huge cost in my view for every 35k or so miles. At £400 and 35k miles it's 1.1p per mile - tyres are much more expensive - especially if you attent track days. Stick a piggy bank on your dashboard and feed it after every journey. My rules (formulated over my years on this forum) to a happy and perfectly reliable timing belt is:-
1. Replace every 35k miles or 3.5 yrs as if your life depended on it.
2. Always always always have your belt re-tensioned after 1k to 1500k miles
3. Always always always replace your balance shaft belts as well
4. Replace your tensioner every other belt service
5. goto 1
Follow these rules and you will sleep easy and will never have a timing belt failure. The timing belt is 100% reliable if these rules are followed. If you can't or wont follow these rules then maybe you should reconsider 944 ownership.
