chrisg
I knew I'd get some flack when I tried to describe what revolving the steering wheel with a bolloxed steering shaft feels like........ Very tight then releases as you move past the uj section that's out of alignment. [
Anyhow, back to the question raised about settings.....
Much depends on how:
1. Your shockers/ ARB set up
2 Tyres you're running
3. Amount of driving track vs road you do
My experience of both the S2 and the Turbo is that anything more than 2.25degrees negative camber at the front makes it very pointy and tramlining -it also wears the inside tyre edge big time ! Even though it helps on track days.
So, as a compromise you could try ~ 1.5 -itve at the front with the same at the back using 0 toe-in. Having fitted the 968 Castor mounts you can get quite a bit of castor - go for as much as you can on each side provided it's matched across the axle (front)
IIRC, depending on the shockers you're running on the S2, there's only so much -itve camber you can get without getting out a rat tail file ?
