So Cargraphic make sports boxes for the 993 that dont fit the 993 ?
What cat have you fitted?
The cargraphic sports boxes are clamped to each side of the standard
cat with an internal sealing ring (olive) with external clamps,
the cat is bolted to the manilolds / heat exchangers, this is where
you have to check when ordering 100 cell race cats as there are two
different systems, Bishoff and Gillet, these have different flanges and
one won't fit the other, bishoff has 5 sided flange with oval bore, the gillet
has a triangular flange with circular bore, the manufacturers name is
normally stamped underside the heat exchangers surrounding the manifold
pipes bolted to the six cylinder heads.
The cargraphic sports boxes should bolt to the standard restrictive rs cat,
and the standard rs tailpipes should also bolt to the cargraphic boxes,
Cargraphic states there sports boxes will fit all 993 models apart from the turbo.
