David Hooper
Have stripped rear down now so as to make it easier to sort brake/fuel pipes. Also to fit polys. And nice new exhaust
The rear spring plates and alloy hubs are suffering from corrosion and were a pig tp part. It's very original at 70k but it has never been apart for alignment. If you've never had those bits apart it's a good idea to strip, clean and protect them. Just before you get the alignment done
The plates into the torsion bar are bad and in fact are suffering from a situation akin to plate lift on the calipers. Past the height adjuster then past the lock bolt they are actually beginning to part
As I said earlier in the year (this car is taking longer than I thought surprise surprise) it may be due to spending all it's life in and around Bristol.
Anyway, was in OPC Towcester today ordering bits so asked Ted how much for replacement spring plates which includes the vulcanised rubber bush that fits over the torsion tube/bar etc.
£330.00 + the VAT
EACH
Anybody got any bright ideas on how to avoid this extortionate expense?
I will get a picture site set up with some before & after stuff soon.
Dave
_________________
Now -- Black Sport. M030 arbs, rear seat delete, CS rear shelf, Goodridge hoses, Uprated discs/pads, Poly Suspension.....it's started!
Ex -- Maritime Blue CS, wave if you see it on a track near you!
£330.00 + the VAT
Dave
_________________
