Hi its me again,
Just had another 718 cayman driver contact me regarding his blocked GPF filter, the car has failed the mot test and his dealer wants to charge him the usual £7,500.00.
Last year I posted some information on the Porsche Cub forum which covered the above issue.
Has you know I worked for the last 6.5 years in an independent Porsche specialist in North Yorkshire I have been involved in my own research regarding issues with oil/air seperators and what happens when they start to fail.
I have helped a few 718 Cayman owners in not having to pay for their GPF filters, they gave their feedback on this forum.
In all my dealings with the these cases it was interesting to see that none of these drivers saw the GPF filter warning light on the dash. This specific light is to warn the driver to regenerate the filter as described in the owners manual.
They all had the engine management light come on, that resulted in a blocked GPF.
Why isnt the early warning light not coming on, and why on every occasion, when the driver has asked, what caused this fault, they were told by the dealer that the GPF as failed.
GPF filters should last well over 100k miles and beyond if the electronic regeneration by the car works, and the filter is free from engine oil contamination.
I would like to ask have any drivers of these cars that have had the GPF filters fitted, did they see this warning light on the dashboard.
Would also like to ask any Porsche dealer, and Porsche Technical, whats the DTC code for the Gpf early warning light when it comes on.
Spoke today with a friend of mine that’s had a new GPF fitted recently, and he is seeing white smoke on start up, when car is left overnight.
This could be the oil seperator finally giving up, he will check his car tomorrow and try and remove the oil filler cap while it's smoking, if the cap is difficult to remove, this would confirm the oil / seperator as failed.
We need to find a solution for this problem as soon as possible, if the light comes on, it will fail the Mot test, then the car is off the road.
I have carried out research on other makes of cars with Gpf filters fitted, and they all have early warning lights coming up on the dashboard. This light instructs the driver to drive the car drive the car using the de acceleration technique to generate more heat in the exhaust to aid regeneration.
Please contact me on 07769 590119, with any information that could help us put more pressure on Porsche to fix this fault once and for all.
All the best
David
