I think the answer to your suggestion, James, is in the title of the thread.....[jamesekirby said:What about a trickle charger connected to the live cigarette lighter socket? I believe that's possible with the CTEK (other brands are available []) and is what they are designed to do... You should be able to permanently fix the connectors to the battery terminals and then when you leave the car in the garage connect them to the trickle charger and plug that into the live socket. There is a cut out in one of the door seals to allow a cable to run and then drop it down under the top of the frunk near the wiper blades.
Charging in a powerless garage
- Thread starter Trickystitch
Trickystitch
Hi,
Thanks for the responses.
Without going into detail I will let the specialist do the investigation. While there is a cost, the practicality is a lot easier.
The car is on a Ctek all the time now but I want to park it closer to me but more importantly be park it in a garage so that after each use I do not have to clean it (put a cover on afterwards).
So will go ahead with the investigation, then see if I can install a solar charger, it not it will be the ignition on and undo the battery.
That's the plan at at least. I'll update this post with the results but it'll be a few weeks away.
Thanks.
Thanks.
Trickystitch
May I add a further question after a bit of thought. The 996 currently sits on the recommended Ctek. We all choose Ctek becauseof it's cycling, protecting the battery and alternator. How does a solar charger cope with this aspect of battery / alternator longevity? Thank you.
Trickystitch
Thanks for that. On the case (Sunstore).
Cheers, Richard
Cheers, Richard
I have a garage a 15 min drive from home for my 996 Turbo - I bought one of these and using a c-tek charger charge it once week - seems to work perfectly.
https://www.goalzero.com/shop/power-stations/goal-zero-yeti-400-portable-power-station/
