Christmas presents....
- Thread starter Guest
cornishgrose
chrisdenton
ORIGINAL: Fen
Ah. In that case I'm sure it will be fine...[&:] Actually if the M030 is set to soft it probably won't be hugely stiffer than the original Turbo cab suspension. I do remember Ray Northway saying to me that my 18's would be too much for a cab and that Turbo cabs are already too stiff for the shell. I didn't believe him for a long time even after running mine on 18's, but when I went back to 16's I realised how right he was. The problem I found most noticeable cornering on broken surfaces; the car feels OK but I found it was impossible to hit the intended apex.
Spot on again Fen. On the softest settings the car isn't noticeably different from before. It definitely is better planted and more direct, but then I would expect this as the original struts were shot. I haven't really pushed it yet on uneven or broken surfaces but my feeling is it will be fine. I'm not intending to play around too much with the setup until I have a full alignment done.
