scam75
Well-known member
No coolant loss. Lambda sensor is about 2 years old. On initial start up once cold start is off it idles mid to high 12's. Once been driving for a bit it idles low 12's. As I said AFR's all good on throttle. ICV seems to be working and lambda seems to be ok. Certainly it calibrates and shows 14.7 with engine off and shows expected readings on throttle. Assuming ICV and lambda sensor functioning ok where should I look next? As already said no vac leaks and no reason to suspect any gasket issues of any kind. Kinda stuck!
Stuart
Stuart
