Clubsport as a daily driver?
Steve, yep that's the one, I know it very well.....[;)][:D]
One that caught my eye is this...
http://www.pistonheads.com/classifieds/used-cars/porsche/968/porsche-968-sport-1994/1418567
It looks like its had a lot of stuff done pretty recently and seems a good price.
Although I have no knowledge of it at all....
Happy hunting.....[:D][:D]
Nerdy question.....why do some Sports have door/side trims and others don't?
it's just a case of what was optioned at the time of purchase, hence the reason some Club Sports have comfort seats and that's what encouraged Porsche UK to bring out the Sport, which although produced on the Club Sport production line, were produced with some of the electrics and comfort seats as standard.
Thanks Stuart, I thought the trims might have been part of the 'sport spec' but have since seen that they're on some earlier coupes and cabs too. So as you say, they're part of the first owner spec.
My Sport had them but my coupe doesn't.
Because of the options available, when you're looking aroud at 968s you probably find that almost no 2 968s are exactly alike.
Colours, side trims, headlight washer jets, seats, rear wiper, side decals................... all could be specified or even deleted from the standard specification.
ORIGINAL: Steve Brookes
Dave, that one has caught my eye too [;)]
Couple of small points :
Cloth comfort seats - smaller wider bolsters than Sports seats. Had these (1/2 leather) on my coupe, they were OK, but the sports full leather seats on my cab are more supporting as the bolsters are higher and possibly slightly narrower - slightly more difficult getting in and out for an old fart like me, but great once you're driving.
Can't see any sign of the luggage blind that should clip into mountings either side near the seat belt mounts, and to the underside of the tailgate. Need that to hide anything in the boot from prying eyes! They're occasionally seen on eBay but are rare and can be pricey!
Many thanks for your comments Chris. Also for your earlier point about a tip option. My first boxster which I had for over 6 years was a tip and a great commuting car and still fun to drive. So I'm certainly not an anti-tipper (is that a new phrase [:D]) but at the same time, something is telling me that the 968 would have to be a manual.
Was the Boxster tip buttons on the steering wheel or paddles? I've not driven either, but one aspect of the 968 tip that I really like is that, in manual mode, you still change gear with the gear stick. To the right of the main "gate" is a small gate, you bring the stick from D into this smaller gate, then press forward to change up, backward to change down - so it's sort of like a manual, but without the added hassle of a clutch! As I said earlier, I was quite dubious when I first test drove the tip coupe in late 1998, but within a month of buying the car, I loved the tip gearchange and would not now go back to a manual. Also handy when herself uses the car - the coupe was, for its first 2 years, our main car, so she drove it quite a lot - but in D!
Another point for the tip is that you only have 4 gears rather than 6. She only goes down the box to 2nd, but that gear is fine for pulling away briskly - and even in manual, if you floor it pulling away it will kick down to 1, or you can manually select 1. 2nd is quite long - doesn't red line until about 75-80mph, and 3rd goes over the ton (naughty but nice!). The box is also quite clever - in auto mode it has (IIRC) 5 modes, and chooses the right one for the way you are driving. In manual mode, you cannot over-rev - red line it without touching the stick and it will change up for you - nor can you go below about 1200RPM without it changing down for you, so you can't pull up to a roundabout in 4th and bog down when you try to pull away (as happened to me test driving a BMW M3 steptronic in 1998 - frightening!!).
The one weakness of the gearchange that I know of is the little microswitch that tells the box you want manual mode. It has a small cranked operating arm with a roller on the end, the operating arm can break - and getting a replacement is a mission. OK, a replacement can be "southern engineered" - it was done to my coupe for a while, and there's a thread on 968uk where another member did the same - but i had to contact the original manufacturer to get a pukka replacement, and he only had a few left.
Another little point - if the car you buy still has the standard ECU chip, get a Promax 7100 chip from Stu (Mr968 on here) on K300/porsche968uk - it improves the mid range by smoothing out the variocam influence. Stu sends good fitting instructions with the chip, it's quite easy to swop (ECU is behind a wooden panel in the front of the passenger footwell, so access is pretty easy as that part of the footwell carpet is held on velcro).
I think M030 is completely usable on road and CS will hold it value. The buckets I find exceptionally comfortable for long runs down to Switzerland and back.
I have LSD and aircon and the CS is a really usable car.
Mind you this is my using road car as the 64RS is much firmer and less enjoyable unless it is a smooth surface.
The KW option is a possibility if you don't like the Konis.
I guess it is all relative to what you are comparing it with?
Just buy it!
The only down sides to owning/using a Club Sport is sometimes that you feel a bit of a twit getting in and out of bucket seats, the remote boot release on the passenger side of the car, no cover over the boot, manual mirrors, no air-con. Saying that it is superb to drive and I am very happy with mine, and it does get plenty of attention. Managed to do a near 1100 mile road trip around Scotland recently which had snow involved.
As far as small battery is concerned, get a battery manager/charger.
Check that the oil pressure is about 3bar at hot idle.
Make sure the belts have been changed and that the cams and cam-chain are ok.
ORIGINAL: Fraser
Any news Steve?
Well.........the Boxster S has now gone and am deciding on the replacement (I've discounted the CS as an all year round daily driver after the feedback here).
Good luck with your search - as you mentioned the Recaro Pole type chairs wouldn't be an issue, but little things like the manual boot release can be a niggle. If you're used to topless motoring, the lack of A/C might also be a challenge [:D] Let me know how you get on - see you at the Gold Cup if not before.
Interesting feedback from you on the GT86 - thanks.
