Clutch life
- Thread starter DavidL
sawood12
I think you should assume £600 ish for a replacement at a specialist which includes the clutch replacement kit which is about £350. It's quite a labour intensive job I believe.
944cabby
That's a similar situation to mine s2cab but i had it done at about 90-95k as it was juddering quite badly especially deccellerating.ORIGINAL: Fen
Replacement is anything from £600 to £1,000 depending on model (early Turbo is most expensive) and if things like crank sensors get damaged removing them.![]()
Mileage depends on use and driving style. My cab had 192,500 miles on it when I sold it and I think it was on the original clutch, but it had spent its life on the motorway. Similarly my Turbo had 152,000 miles on it when the engine was pulled out and although the clutch wasn't slipping it was down to the rivets, which were biting into the flywheel rather than slip.
The mechanic that did it reckoned it was well worn and had it been left much longer the flywheel would have been damaged.
Got the clutch kit (Genuine OE Sachs) from Bert at Berlyn Services, had it fitted by PH Sportscars near Derby.
Dave K.
Diver944
http://www.porscheclubgbforum.com/tm.asp?m=8697&mpage=1&key=clutch⇹
My S2 is still on its original after 165000 miles (75000 by me)
My Turbo had a new one at 72000 miles (when I bought it)
Either you're imagining it (always possible!), or you have contaminated the clutch plate with something. How leaky is your rear main seal?
lookingfora944
Thanks for the replies. Its a 944 S2, I don't see how I could have contaminated it. I have only had the car a couple of months and I had it serviced and checked over 3 weeks ago, so I don't believe there are any oil leaks. Maybe I am just being paranoid. Since I bought the car pretty much everyone has been negative saying how much it will cost me blah de blah and it may be something as simple as loss of traction, as you say. It definitely had no problem on the M-Way earlier.
I will see how it feels tomorrow
Definitely loss of traction then!
Really, they are so powerful and smooth, they break away without you even being aware of it. [
(Sorry, bit of an in-joke here. A serious answer would be to see if it happens again and worry about it only if you get some more definite symptoms. Oh, and they don't cost a fortune to run at all; 'pretty much everyone' is pulling your leg.)
lookingfora944
(Small note to Simon; while I am sure white turbos may have the occasional problem with traction, it's nowhere near as bad as in a white S2. 'Cos ... well, it's obvious really. [
Nice that we got that one cleared up so soon, chaps! [
As they've said, depends how the car's been used, lots of town driving and wheelspin starts won't have helped, but that's not to say you can't enjoy it...I've driven at Brands Hatch, Prescott, and Shelsley but always with a thought to the less robust parts of the drivetrain!
Anyway, if there's any clutch slip you should be able to hear the revs rise if you, say, put it under load going up a steep hill. If that's the case, then maybe look for some other signs of an oil leak?
And so far as the negative comments are concerned, well just enjoy your car...most accept that it can be expensive at times. So...
(Small note to Simon; while I am sure white turbos may have the occasional problem with traction, it's nowhere near as bad as in a white S2. 'Cos ... well, it's obvious really. )
It is indeed obvious, Oli : those of us with boooost also have limited slip differentials.
And I'm sure you chaps need them too - what with that untidy, lumpy power delivery! Give me the greater power with the smooth delivery of an S2 every day of the week - even if that means I need to tame the waywardness of the back end a little! [ORIGINAL: Lowtimer
.... and on a serious note, I changed the clutch on my S2 at about 140k-or-so miles, and the one that came out was - I think - the original one. It seems that a fair number of original clutches are being changed 'cos the rubber centre breaks up, not because they wear out. (Although the symptoms from the OP are not those of a broken-up rubber centre.)
pauljmcnulty
That's forums for you. [&o]
To be fair, this forum has been going for nigh on ten years. If you imagine how many times the long-termers here have seen people register with a cheap car picked up on e-bay, then complained about all the things wrong with it, you'll understand why people are a little less than forgiving sometimes!
A 944 will cost you, of course. And far more than a modern car if you only count the service costs. Factor in the cheap purchase price and the nominal depreciation and you're laughing.
Oh, the clutch? 100K should be fine unless you're racing it. 28K miles is probably still bedding in. [
What were you driving before? I guess you're just being caught out by the wide tyres, slippery roads and lack of modern traction control, causing a bit of wheelspin. Often you won't feel it fishtailing around, as the car is so balanced, but the rears will be struggling to find grip. Every year I include "be careful out there" during the winter months in the Register article, because I deal with so many insurance claims where people are surprised how easy it is to throw a powerful car off the road when you've not got electronics to help you.
