peanut
I've been chasing a hard cold [style="background-color: #ffffff;"]start[/style] and rich erratic idle problem with my car ever since the current cold spell set in.
Two weeks ago the car started instantaneously every time , as always, with an immediate stable idle and perfect running.
One morning I went out to take the car to the garage for its MOT and it wouldn't start until I had given it full throttle and pumped the pedal like crazy. (It subsequently failed the Emissions with a CO of 10.031 and an HC of 1239)
For the past week I have reaquainted myself with the Bosch manual and trawled the net looking for similar cases in the hope of narrowing down and pinpointing the cause of the problem.
Not wanting to fall into the usual trap of fitting a whole raft of new components to the car until it hopefully starts working again , I tried all the obvious checks first .
TPS stripped and conacts cleaned click reset voltage and resistance OK
AFM stripped... wiper arm cleaned adjusted and solder bridge to bridge arm etc Voltage and resistance OK
Engine Temperature Sensor Voltage & resistance checked OK
Idle Control valve voltage & resistance OK checked operation with 12v battery OK
Vacuum hoses spray checked with carb Cleaner. no leaks found.
FPR and FPD pulled vacuum hoses whilst running. No fuel let by, OK
Pulled the ECU opened up check for damp /condensation. Cleaned connector terminals .
Getting desperate now .....I test and clean the entire Ignition system and change spark plugs...
Still no change ....so I'm thinking I can't put it off any longer I'm going to have to check Fuel pump flow and pressure even though the car is running like a dream and pulling like a train right up to WOT.
I pull off the fuel rail pressure test nut and am surprised to see absolutely zero fuel ,,,nothing , nada zilch.
Connect length of garden hose and bottle to the fuel rail to check the flowrate ....switch on the ignition expecting a momentary squirt of fuel as the fuel pump fires and shuts down but see no fuel at all ? Ah ha ! thats not right surely. Beginning to wish that I'd trusted my gut instinct and gone straight for the fuel pump and injectors from the off ..
I'll have a read of the bible tonight and draw up a list of ECU tests all the sensor and fuel system inputs and outputs for tomorrow but at the moment I'm expecting to find that the ECU is the culpret in all this , probably due to all the damp and condensation in the car this past 2x weeks . I hope not,.. as that is going to be really expensive to replace. I will also check the flow rate and performance of of the injectors as one or more may be leaking which would cause a rich idle and loss of fuel pressure
UPDATE 1st March
Well there has been some development so i thought I'd add the outcome and current status to the thread here so that it is easier to follow progress if any.
I managed to start the car and get it to the garage last week and eventually got the emmisions right down to get an MOT pass however the rich idle mixture issue has not gone away or been cured yet so I'm still looking for the cause and a permanent solution. Heres what happened at the MOT station.
Quick recap car suffers with a rich idle mixture. It would hard start on full throttle and pumping, then cold or hot the idle would hunt from 600rpm up to 1200rpm and back continuously until eventually it died from the plugs sooting up. The car revved normally and performed faultlessly with perfect throttle response up to WOT.
At the testing station hooked up to the exhaust emissions analyser for the MOT retest the levels were still too high . I tried removing the connector for the ICV (idle control valve ) and within a few seconds the 02 and HC levels had dropped significantly .I believe the default condition of the ICV valve when disconnected is fully open as per cold start condition ?
With the ICV disconnected I also removed one of the vacuum pipes and the 02 then immediately dropped further from 10.031 right down to 1.783 ! within 8-10 seconds. (pass is 3.500)
At the same time the HC also dropped from 1239 down to 138 ! (pass 1200 ) Amazing !
. So presumably the ECU had registered the extra air supply and adjusted the pulse rate to the injectors to lean the idle mixture back to normal .?
Now I've just got to figure out why the engine is getting too much fuel at idle or insufficient air or whether the ECU is either faulty or not receiving the data from the AFM, ICV, or engine temperature sensor etc,
New pump ,strainer, filter and engine temp sensor have now been fitted and the fuel pressure is stable at 3bar .Leak down test and flow rate are fine too so I'll start with cleaning and testing the injectors as the car has been stood unused for long periods over the past few years.
Following that I'll have to test all the sensor voltages in the ECU connector to make sure that the ECU is seeing what it should.
