I'll stick to this thread I think until this cold hard start and rich erratic idle issue is completely resolved.
Hopefully when it is resolved I can tidy up the thread and it will be a useful go-to resource for other owners when these issues effect their cars....and it will
So.....you know the old saying 1 step forward 2 steps back ?....well its pretty apt for my ongoing issues with this 944S2 this week.
Yesterday I removed the Idle Air Control Valve from the car and thoroughly cleaned it. its really easy to remove the IACV from beneath the inlet manifold. Don't whatever you do be tempted to remove the inlet manifold unless you have other work that requires the manifoldn to come off. Its 15 minutes work tops ! I'll attach a youtube video I made to show you how easy it is.
OPERATION
So ....it turns out that the 944S2 IAC valve is a revolving valve operated by a coil winding type solenoid housed in the body of the valve. Unlike the earlier 944 which have a 3x pin IAC, Later cars have a 2x pin connector.
The 2x pin IACV is fed a constant 12v+ and the valve is maintained in its normal default
open position by a strong internal return spring. For normal warm running the IAC valve is kept closed against the spring pressure by the ECU which grounds the solenoid coil of the IACV .When the ignition is switched off the IAC valve loses its 12v+ supply and the powerful return spring opens the valve once again ready for the next cold start.
If the car is restarted some time later with a warm engine, the engine temperature sensor tells the ECU that the engine is not cold so it grounds the IAC valve ,...closing off the additional cold start air supply that normally bypasses the throttle for cold starting. Thats how I figure it works but I still don't really understand its operation fully
So its simple to see how critical the correct operation of the ETS and IAC are to cold starting the 944 engine.
On examination it looks like all the condensation this Winter together with the lack of use of the car had caused the internal surfaces of the valve to oxidize and expand slightly which effectively jammed the valve .A little carb cleaner and careful cleaning with bits of rag via the hose spigots soon cleaned it up fine and flashing the valve with a PP3 9v battery soon had it working smoothly again.
I was initially surprised that the 944S2 AIC valves default condition is open.... I had assumed that it would be the other way round but I suppose if the IAC valve were to jam or fail ,you'd want it to fail
open so that the car could always start when cold. The rest of the journey the mixture would be rich but it would run and the ECU can compensate to some extent by adjusting the duration of the injector pulses every revolution of the engine.
Anyway I digress as the little man would say.
Today I reinstalled the IAC valve to test the cold start....absolutely no difference ! grrrrr
When I pulled the connector off the IAC valve during warm up, the engine promptly died !. I'm sure that that is diagnostic but I can't work out how right now...I need to eat and then i'll tell you all about another interesting development.
YOUTUBE VIDEO REMOVING THE IAC VALVE
https://youtu.be/yHAajWoRV6E
