Thanks guys. I really don't have any remarkable qualities as a human but for some odd reason I've persisted with this platform. Some sort of unreachable quest it seems. There are many things I'd change if I could wind the clock back, but we could all say this no doubt. [
George
I don't see a real issue with the bigger bore motors but that would somewhat depend on the intended use. For a fast GT coupe that sees the occasional trackday I wouldn't hesitate to continue with the increased capacity...provided it was put together avoiding some of the usual pitfalls. With a race car that is seeing extended periods of higher boost and rpms then it's possible to rethink the bore size. On the 16v motor we have been discussing dropping the capacity down to a 2.2 - 2.4ltr motor but this is on a totally one off type of build. I really think the main problems with pushing these motors is the near 30 year old Alu blocks/heads and the spacing of our main studs. They are so wide apart compared to many other 4 bangers. Challenging to keep the seal in place. We feel that the copper gasket / bronze sealing rings have worked, but with this new motor we anticipate having to boost more so that will be put to the test.
I can post a ton of pics of all the parts but it's not so user friendly in this forum and takes time while I'm sitting at work, so I will describe as best as possible.
-Crank: I bought this many years ago via Chris White in the US. Apparently it was sent to LR for medium lightening but came back fully knifed. I don't have the weight of that crank but take it for granted that there were many lbs shed. We've had this sitting in the shop now for a little while and the few experienced builders that have happened by all point to that as being the likely culprit.
I supplied it to my builder in the US and this was to go into a larger bore street/club motor so perhaps he wasn't overly concerned. In retrospect it would have been better had he made a call on this crank when the motor became more race than street...however...
-Rods: Were also supplied by Chris White. They were Arrow rods which you know are of good quality. The pistons were forged CP and yes they were balanced.
-Flywheel: Is lightened stock. Can't recall the weight but a few lbs off stock.
-B/shafts: Stock. NOT deleted. Seems to be polarising opinion on these for a race car but I think unless you build a motor from ground up, it is probably not worth the risk of deleting them. I know there are a few people that have had success without them but I don't believe the cons outweigh the pros as such. We didn't have an S2 pulley/dampener. This time we've sourced one from the US that from RS barn. In the 16v motor I would source something even better.
My feeling is that with the dampener and stronger crank, plus lighter parts we should go a long way to 'curing' the ugly harmonics that beset the last motor. In terms of the 'ellipse' I referenced, I mean that with the longer rods/shorter throw plus the smaller / lighter wrist pins which are located higher in the piston, the motion of the new setup vs stock specifications should be less aggressive inside the bore. The piston won't 'fall over' as much at the top and in general should provide a smoother engine. Bear in mind, I'm not an engineer so my description is probably pretty poor! The builder/engineer sent me quite a technical email but I lost my phone and that email so I can't find the info. A more specified list of the parts below.
NA Block
Doweled Girdle
Line bore checked
Polished internally
Deck plate fitted
Steel liners fitted and honed to 102.00mm
Race prepped Bearings
Bull nosed Crankshaft with narrowed journals, balanced to new Piston and Rod weights
Carrillo Rods, increased CCL to suit shorter Piston Comp height
CP lightweight boxed strutted Pistons with DLC pins, gas ported for low tension ring set
Piston Oiling Valves fitted
9/16" ARP head studs with 12 point nuts
Updated for late tensioner assy
NA 2V Cylinder head
Ported both sides
49.00mm x 5/16" Intake Valves
43.500mm x 5/16" Exhaust Valves
Ampco 45 valve seats
Ampco 45 valve guides
PD race valve springs
PD Titanium Valve Spring Retainers
PD Titanium Valve Locks
Stainless Exhaust studs
Machined for stepped head washers
PD stepped head washers
Arrow solid Cam Followers
PD Camshaft
Modified cam housing
8v head results on flowbench at 28" test pressure
Lift - Intake - Exhaust
0.050 47 26
0.100 82 59
0.150 114 92
0.200 141 111
0.250 163 133
0.300 187 151
0.350 212 171
0.400 235 182
0.450 257 192
0.500 265 200
0.550 273 206
0.600 279 211
"This head keeps flowing. The cam lifts are 0.595 and 0.526". So disregard
the flow numbers above these lifts. But it shows this head does not go into
choke even up to 0.600" lift. The exhaust goes sonic even on the bench so I
know the velocity is high. You can hear it crack!"
