Cookie cutters
- Thread starter swb landy
frankydoom
AGGGGHHHH dont say that. . . . . . . .got me double checking now. . . .ORIGINAL: frankydoom
Cool - ..... best part is when they turn up and don't fit ........ I had a few cider moments before ;-)
924nutter
My car is a 1986 oval dash car, but has the pressed steel wishbones and no abs. The wheels that are fitted are 16" cup wheels, and they have i think, 15mm spacers on the front and 30mm on the back, so i,m assuming the early cookie cutters will fit, they are all listed as 7j. . . . .fingers crossed eh. . . .[],
Dave
944 man
ORIGINAL: swb landy
OOOHHH. . . . .looks like i have opened a can of worms. . .
Dave
They will fit perfectly. Theyll look a little wrong though, but itll be made up for to a greater degree by being quite smart.
These and the wheels fitted to your car originally were both 7" wide, 15" in dia., with an offset of 23mm.
ORIGINAL: 944 man
ORIGINAL: swb landy
Dave
When you say they will look a little wrong, is that because the wheels are wrong for the car. . . .or for a different reason. . . . .my head is hurting even more. . . . BUGGER
944 man
Series one 944s (MY82-MY85) used steel wishbones and steel rear trailing arms. Series two 944as (introduced in September 1985 for the 1986 model year) had similar dimensions but the steel arms were replaced with amuminium. MY87 cars had different front arms and ABS was iffered as an option. These MY87> cars use a 52mm offset wheel, as opposed to the 23mm offset wheel used inthe series one and 1986 series two.
