cooling fan wont stop
Series two cars inc. 968, I believe.
Series one cars and 924 / 924S:
Simon
Simon, thanks for that. I've actually just read a similar thought elsewhere - that it will run a little hotter with a new thremostat in.
According to your diagram, mine is running spot on now.
I just want to be certain that the fans are cutting in when they should.
it is a proven fact that engines run better at lower temperatures not higher .The standard 944 engine's most efficient running temperature is at the first mark on the gauge where it was when the car was produced. That is why the gauge has an indication mark in that position A hotter thermostat is not an improvement in my opinion.
fitted new thermoswitch tonight all seems to work ok but while fitting it the horn fell off and disintegrated even though i was no where near it! think she is trying to tell me she wants air horns instead!
ORIGINAL: smiffyraf1
Know how you feel. The problem I originally mentioned earlier has ended being the most obvious thing - a tiny leak from my radiator. And when I fixed that, my starter motor packed up.
Keeps me busy, I suppose.
