924nutter
Can be the sensor in the radiator but as precaution pull the fan relay until you get a chance to sort it but remember to refit it before driving. Clarks garage covers the onerous task of replacing the rad sensor. I have a little bit of trouble with mine, when I switch off the fans run at full speed instead of going to slow speed, I just wait until they switch off. Being the sort of person I am, I am going to peel back the peening on the relay and see if the contacts are stuck because I think that if the fault was with the sensor the fans would not stick in high speed because regardless of temp, if the fans have cut in, they should go to slow speed as soon as the ign is off
