SimonExtreme
Laurence
Unfortunately, I think this is a bit of a Forth Bridge situation. If you try doing it in bits, you end up starting again at some time and it becomes a endless process. Having been in your car, I suspect that both struts and springs need doing. Your car cetrainly felt more "wallowing" than mine.
The question then is whether the bushes are an issue and ultimately, whether the front wishbones are OK. Having spoken to various people about the subject, the wishbones tend to be a function of the amount of track time the car has been subjected to but once you start on the bushes, you are committing yourself to wishbones if they are found to be needed.
