John H
Porsche disks do corrode very easily, but regrettably many OPC's play on this fact to railroad customers into changing disks and pads as soon as possible. That said, at 4 years old and 25k miles, your disks probably are getting to the end of their days, especially if they are showing wear marks like the rings you mention. Is the car garaged? Do you religiously dry off the disks every time you wash the car? If not, the dreaded corrosion very probably has got a hold. My own car is just on 4 years old, has done 35k miles and is still on the original disks (although second set of front pads) and I reckon I will have to change at least the front disks fairly soon. The back ones get an easier life, and will last a bit longer. I am pretty light on the barkes, and I am fastidious about drying them after a wash, but I doubt if they will last much longer. You can of course buy the parts and do it yourself (not terribly difficult) or you could use a good indie who will do it for a lot less, but the sad fact is that modern Porsche brakes do not last long, and you will need to fork out sooner or later.
