CTEK Car Charger
- Thread starter Bear911
As far as I'm aware there's no difference between the Porsche and CTEK battery conditioners, so save yourself some money and buy the latter.
The charger comes with crock clips and also with an eyelet connection, so you can choose how you connect the conditioner to the battery. You can also purchase a cigarette lighter connection; but watch out, because on some Porsche variants the socket isn't always live when the ignition is switched off, although I've a feeling that the footwell socket is always live.
I've used an older version of CTEK conditioner for nearly 8-years and can wholeheartily recommend one for use on a lightly-used car.
Jeff
plherbert
They sell a 3.6amp (£95) and 5amp (£141) pro model that connect to the cigarette lighter. Both branded Porsche obviously but heard CTEK made them for Porsche. My question is how does the CTEK one that the Porsche club sell for £58 differ. To be honest the pics make it look like it connects to the terminals of the battery, quite like the idea of just plugging into the footwell, is this possible with Porsche Club offering? Clearly happy to buy the PCGB model as it's quite a saving but keen on the cigarette lighter connection? Anyone own this model?
Thanks in advance
plherbert
Anyone from from the club care to comment or anyone who has purchased this item?
As far as driving it more, would love to but got my hands full with a newborn...
I've used it over two winters (probably pointlessly as my battery is young) but it is does the job.
I plug it in the lighter socket which is easy and minimum intervention (many years ago I got the terminals wrong in the dark on jump start- on a cheap car fortunately-and you don't want to go there).
That said the ctek is a little erratic, sometimes you need to leave it half an hour or so to get a charging light confirming it's doing the business. Don't expect mobile phone type responsiveness (this is probably normal).
I paid the premium over generic for comfort that this was a state of the art product (googling will reveal this).
I paid less than Porsche branded because I suspected Stuttgart were clawing back some of the value you get when you buy a new car, especially one with low non-technical spec. (A theory-possibly paranoid- that began to build when I changed my oil and got ready to insert a nice new Porsche filter and pulled out the old one-a Mahle from the 2 year change by the dealer -the dealer won't be wrong it'll be Porsche approved it just costs 25% less, ok only peanuts, but the principle remains).
plherbert
Interesting reading how the battteries can detiorate without a conditioner/charger!! Understand why people put Bosch batteries on now!!
Ivan Ford
On my 991.2 the interior sockets all turn off shortly (about 30 minutes) after the car switched off.
It's not that inconvenient as the lead is under the front bonnet or is it boot...........
As the car is garaged I just leave it open, when you lock the car the storage compartment light goes off, but it's possible to gently close it on the lead if required.
TerryUrquhart
i have it on mine but it crossed my mind that I had read why it was separate?
STiG911
like I said I use the bolt-on terminals and run the lead out of the wiper end of the bonnet as there's no seal. Saves damaging the door seal trying to use any of the lighters.
you can just see the disconnect section by the mirror.
plherbert
As far as the Moll battery is concerned, I did read they weren't maintenance free, however my OPC told me they needed no attention as far as fluids were concerned! Clearly this was poor advice, maybe they are referring to the new OEM battery for the 991 AGM style batteries. I'm finding knowledge of 997 specifics slightly less available as they probably work on less and less of our cars!!
Also have Porsche charger that only has the cigarette lighter adapter that I use for the Boxster, this also works well.
I used to use Historit to store one of them and they use the 3.8 for all their cars and they have hundreds, got to be a good recommendation! Useful indicators on it that tell you the state of your battery.
plherbert
Thanks for the tip, just ordered the CTEK MXS 5.0 with cigarette lighter adapter, was thinking of plugging in as above, but as my car is in a car port, thinking it might be better to have the transformer inside the car? Also can you lock the car as normal with this operating and cable along the bottom of the door as you describe!!tscaptain said:Just a thought on using the cigarette lighter socket. I use the one in the centre console with the ctek unit cable going in the bottom of the door, centrally. I figure that if it does cause any distortion to the seal, along the bottom of the door will be least problematic! That said it doesn't appear to grip the cable tightly at all.
Mike
