mik_ok
ORIGINAL: pikey7
To get the handling characteristics the same, you want to get the centre of the wheel in the same place as the old ones. to move the centre changes the king-pin offset (the distance between an imaginary line from the upper and lower mounting points to the hub, extended down to the road, and the point on the road at the centre of the wheel.)
The problem with this, is that if you go with a wider wheel, this moves the inner and outer edges of the wheel inboard and outboard respectively. This scenario means that the outer edge of the wheel can rub on the arch during steering and/or suspension travel.
The latter point would be valid if you were trying to squeeze enormously wide rims in, but you aren't.
Hence the former point takes far greater importance, and to achieve this you need 30mm spacers all round. Unless you want a slightly "squatter" look, in which case go by my comments above. (The front can take an extra 5mm with no ill effects on the steering, and the rear can take a little more, 'cos it doesn't (usually!) steer).
