Dansk sports or sound exhaust?
I have just stuck with the single pipe outlet. The are more oval than the original, but look good. I would put the photo on here but can't seem to add a photo??
I had the same problem trying to update my profile photo , I got PCGB office to do it for me in the end, I've requested you on Instagram by the way ??
An update on my exhaust choice.
I had a Top Gear Stainless system (2 x mufflers) fitted this week - it's also called a Power Flow system.
Compared to the Dansk the Power Flow was less expensive fitted (including fitting kits etc) than the cost of the Dansk Parts alone.
The Power Flow is stainless and is guaranteed for 'life'.
Very early days, buts what's it like? I went for the 'mild sports' option (there is a full sport option that is louder), the system that was taken off was so far as I can tell the original one. The new system is quieter at both low revs and at speed, but the old one had a slight blow so it was probably louder than it should have been.
The Power Flow system has a different tone to it, it has a deeper rumble and a less metallic high end note. It has a fuller sound to it, more like you'd expect from a bigger engine.
I'll update if I get any issues with it.
