on facelift cars so however hard you look, you may not find them!
nice idea regarding my "research" on the M6!
Pre-facelift cars had ones that clip on the air vents, or you could buy a two-cupholder retrofit kit which goes in the top position of the centre console. (You have to move the a/c panel to the bottom). If, like me, you have the leather covered side vents, then you are stuffed.ORIGINAL: Diesel130
Where are the cupholders? I can't see any.
ORIGINAL: Richard Hamilton
When I fitted my garage door operator I recovered £13.50 in loose change stuck in the centre console. Hardly the same street value as a stash of coke, but a nice bonus nevertheless.
Since getting the Turbo, I was aware of the stupid LED in the door handle which is supposed to illuminate the ignition lock, but is about as dim as a glow worm's armpit. I didn't realise that there was also an "orientation light" in the overhead console which is supposed to "project light onto the cockpit and centre console area and also serve as an orientation light during night-time journeys. The slight brightening effect generates a greater feeling of space whilst at the same time improving the ability to see the switch controls."
Not only that, but it has TWO settings - useless and comletely useless. You use a ball point pen to switch it from dim to incredibly dim.
ORIGINAL: richard hall
this might even surprise the anoraks
I have had the charger on the car just to keep the battery topped up
I noticed that it seems to take forever to reach full charge
Anyway we all know there is a coutesy light in the front well,I had carefully disconnected this whilst charging
completely dumbfounded as to why it was taking so long I walked way from the car in disgust
Only to notice there was a similar light on in the engine bay
The rear hatch was shut I checked but the light was still on
Until I shut the bonnet
Now unless my wiring is hookey
Why in gods name would Mr Porsche do this
over to you Richard
That's normal, but when you press and hold the button to lock, the windows should go up, and the sunroof should close.ORIGINAL: adrian996
Ok - try this one. I have a sunroof. Car locked, all windows closed and sunroof open (tilted). Press and hold the main button on the keyfob and.....
...car unlocks and both windows go all the way down.
Please don't bother telling me if there's something wrong with my car![]
Adrian.
Adrian.
ORIGINAL: Andrew Grabham
Does this apply to Targas as well (as mine certainly doesn't do this with windows or roof)?
Andy
ORIGINAL: Aviator29
ORIGINAL: adrian996
Unbelievable timing, Richard! Just yesterday I discovered that if I press and hold the lock/unlock button on my key fob for a few seconds it will close anything that I've left open and then lock the car too! Eg. It'll close the sunroof and both windows if needed! I've owned my car for four years.[]
And if you hold it down when you unlock it will put the windows down for you as well!
Mark
