differences between early and late 993
- Thread starter Diesel130
Pickled Piper
Some 993 anoraks will be along in a momen to desciribe any differences to you[
pp
http://www.porscheclubgbforum.com/tm.asp?m=219791
Sundeep - What is the differences in the seat design?
cheers
Pete
Pickled Piper
What were the changes in the gear ratios? I though this only applied to US spec vehicles.
pp
ORIGINAL: burrow01
Some of the differences are highlighted here:
cheers
Pete
the seat design was more 964 with their trademark side bolsters........... have a look at the pics of a 95 v 96 car and you can see the difference, but that's because IIRC there was only 1 seat option early on then there were 3 for the V's normal, Sports and Ruffled
and IIRC we got those long '21' ratios for the V's
ORIGINAL: MoC2S
And also, regarding 2 ferarris (!!) statement, the wheel offsets were ...
16" 55F 70 R
17" 55F 55R
18" 52F 65R
for narrow body only of course (40R wide body 18s)...
cheers, Maurice []
Hi Maurice,
I've just checked on the back of mine, and they are ET70 wheels..('94 model)
Pete
38F3E1
Ian.
Porker993
ORIGINAL: ian_uk
I have to agree with early 993s being fitted with 17" cup 2s using ET70 rather than ET55 as I have seen some with my own eyes. Haven't seen enough to know if it was all cars and when the change over was made. Unless they originally came with 16s and when the owners swapped to 17s they kept the same offsets (by mistake???) rather than going to ET55.
Ian.
I'm very confused, but curiously interested. What do "ET55" and "ET70" mean ??
If it's of any interest, my '94 car has 17s which are presumably original as they are specced on the original options list in the service book and on the label under the front lid.
38F3E1
ORIGINAL: Porker993
It's the offset of the rear fixing surface (ie the bit on the wheel that fits against the hub) from the centre line of the wheel in mm. ET55 means 55mm offset from center line etc. The lower the offset the more the wheel sticks out.
If you have original 17s it should have the size and offset stamped next to the valve stem (eg 9 one side for 9 inches and 70 the other for 70mm offset).
Ian.
38F3E1
I know Laura has the 17 inch ET70 wheels fitted to her 993 but I think she is on holiday at the moment. I am sure they had 9 / 70 stamped on them. We talked about them at the last meeting because her wheels did not stick out as far as everyone else's.
Perhaps Porsche raided the 968 parts bin for early 993s.
Ian.
38F3E1
However they do drive differently IMHO. The 993 pre-varioram has to be revved more as the power lower down is not so good as in the varioram cars. If you drive the two back to back you can tell the difference.
Ian.
jacksonrj4098
